Does anyone know if I can change 2014 ST foot-pegs to Ltd Floorboards?
Kdub757
I own a 2014 ST Base and wanted to change the driver foot pegs to the limited floorboards. Does anyone know if this is possible?
I own a 2014 St base and wanted to change the driver foot pegs to the limited floorboards. Does anyone know if this is possible?
If you have an SE trans., it's fairly easy to make some ..... I did for my 14 RT, that also came with Pegs .....Mike :thumbup:
Im not very good with fab work, but I wouldn't mind hearing your process.
I made a cardboard template to the shape I needed ..... for my RT I had to take off the rubber on the Peg, THAT WOULD BE THE MAIN Support AREA ..... I made the floorboard long enough to reach an OEM bolt that was already there.... I used that to bolt an "L" bracket under the floorboard. The left was easier to shape .... the right side needed a cut-out so the footbrake could function properly. Because the board is angled down at the front, the Brake would go past NORMAL to EXTREME braking without issue .... I just checked the PARTS Fiche' for your model .... I don't see an OEM floorboard for the Limited .... If you can post a pic that would help ..... after creating the cardboard Template I got a piece of 1/4' alumin. diamond-plate and transferred it to that. .... A friend used His plasmacutter to cut it out .... took about 15 minutes if you take it to someone who has a plasmacutter ..... Mike :thumbup:
I did actually look into this process and found a couple of people that did it. But then I found some floorboards online. Thanks for the assistance though. That was going to be my go-to process.
