Does anybody know who sells/makes Passenger Floorboard Risers??
View from behind
We are riding a 2015 RT Ltd and even with my passenger floorboards in the highest position I need at least another inch for my feet to really sit flat on the boards. Does anyone make a riser or have a suggestion?
Thanks.
riser
Yes, I saw this a month or so back and one of the vendors does make a bracket that allows an increased height for the passenger foot rest.........but who ???????...............sorry Mike :bbq:
DIY
There are many homemade remedies. Most common are the blocks form fitted to get you that extra inch or so. But the link above will be a ready made solution...:thumbup:
results of your search
View from behind;1108185 said:
Looking into it, thanks:yes:
Others are interested in what you turn up. Can't tell much from the pictures on the Spyder Specialties site.
I'm particularly interested in seeing others' attempts at riser blocks from commonly available materials.
Pete
Here's what I did. Just takes a little enginuity(sp):
attachment.php
This what I did on my floorboard, but I assume that it will work on the passenger's. 2 pieces of 3/4" plywood and added the hiway pegs.
Hey MS. Looks like you found an answer to add option so passenger can stretch out a bit.
Would appreciate any info you can share. I've this project #1 on my to do list.
Got quite a few questions....can we talk via phone?
Rick Campbell
Blairsville, GA
PM me for my number...
Rick Campbell
Blairsville, GA
You may stand a better chance of getting a answer if you PM them this post was started in 2016!!!! Good luck!!
My wife and I purchased a 2024 RT limited. She is 4'10" and needs risers for the passenger floor boards. Anyone know of any or have any suggestions?
On my 2023 RTL, I was able to adjust the foot rest up several inches for the Mrs (same reason as yours). It appears the foot rest has several height adjustments that you can choose from, only requiring the removal of one bolt. Take a peek at the footrest and you can see the multiple threaded holes the footrest can be moved to. Maybe something simple will be a quick useful solution that will work. Good luck.
Driving a Spyder: Side effects may include smiling.
