^ Wot 'e says!!
I dunno, maybe it's the rough roads here in Oz that aren't as 'smooth' as your 'super-slabs' over there; but I rather suspect that it's more likely the poorly considered hitch mounting/placement!![]()
Care to share some info on it EdMat?Like this?
Like this?
Slowing the heck down would be even better idea to solve the problem! Sorry to be a party pooper!Right on EdMat! That could help solve a lot of folks' problems with bouncing trailers. Thanks
The hitch on the Spyder is in a location that is un-sprung. Meaning that there is not a suspension between it and the road bumps. Hitches on cars/trucks/etc. are mostly in a sprung location - separated from road bumps by shocks and springs. Regards, Don^ Wot 'e says!!
I've seen a LOT of trailers (including a few BRP trailers) damaged by the constant pounding they get from the OEM Hitch or the clones of that swingarm mounted hitch; and I've heard of quite a few more experiencing similar failures, well into double figures!!
Thank you all for input. I was mostly concerned about handling characteristics.
By the way, how much weight do you think these hitches can hold? I was thinking about making a golf club bag holder to screw on in place of the ball when I’m not pulling a trailer
On some of the roads I have been on, slowing down seems to limit the sharp loading on the trailer tongue, but it does not eliminate it. As long as the trailer hitch is connected to the swing arm it will always happen! The shock system on the tongue should reduce it.Slowing the heck down would be even better idea to solve the problem! Sorry to be a party pooper!![]()
Agree 100% A good suspension under the trailer and brakes would almost make it a perfect package.On some of the roads I have been on, slowing down seems to limit the sharp loading on the trailer tongue, but it does not eliminate it. As long as the trailer hitch is connected to the swing arm it will always happen! The shock system on the tongue should reduce it.
I have actually seen and experienced a little those sorta road conditions over your way Gwolf (I lived & worked in Seattle for a while, and extensively toured the NorthWestern States, as well as visiting/touring quite a few other States on the East Coast & across the South of the US, just not so much in the middle/North...), and in a lot of other Northern Countries too; and I'm still firmly convinced that the vast majority of your road network is FAR BETTER than that of most, and certainly that of the Oz road network; while the 'really bad stuff' you mention (which is still better than a fair bit of our 'good' stuff) is found on a tiny percentage of your road network, and I suspect that most US Spyder Riders tend to avoid those bad areas/sections as much as they can anyway.
Here in Oz, even for those Spyder riders who religiously avoid riding off the blacktop, if you want to ride pretty much anywhere/on anything but our Highway 1, which goes around the perimeter of the Country, you'll really have no choice but to spend quite a bit of time riding on roads that I never saw the likes of over your way, apart from the odd bit of damage that was already being worked on and except for when I got to go out 4WD'ing and we went 'off road'... Some of the '4WD Only tracks' I travelled on then were in significantly better condition than many of our 'Secondary Highways'!
Talk to PeteOz about it - he's gone so far as electing to quit riding completely, largely because of the condition of all/any of the roads in his area, and how much that was detracting from his riding enjoyment!
But the point of my post was that the swing arm mounted hitch is a very poor design choice that is contributing to a LOT of trailer damage - how much harder/more expensive would it have been for BRP to design/manufacture a hitch mount coming off the sprung frame somewhere, or even off the leading swing arm bush mount area instead of the continually moving and un-sprung rear wheel axle in such a way that it pounds any trailer to death on anything but the smoothest of roads?!?![]()
