Disconnect Battery
On my 2013 ST L . . .
The battery is in the trunk. It has a plastic cover which requires a (I think) 4 mm Allen wrench to remove. After that, the battery cables are attached with Phillips head screws.
WELLLLLLLLLLLLLLLLLLLLLLLL!!!
How do I disconnect the battery?
:dontknow:....I would just undo the bolts .........................................................................PS , do you think we all know what type of Spyder you have ........it matters
Remember...!!
disconnect the black (ground -) first then the red (positive +) next and hook them back up red first then black. Keeps from messing things up blowing fuses and scaring yourself...:roflblack:nojoke
storage
Have to store the RT next summer with no power available. So I guess I should disconnect the battery. Can that be done in the frunk at the two posts at the top of the left sidewall?? Would just as soon not dig into the bottom to get to the battery.
Thanks.
