Disc lock??
If you put the disk lock with a motion alarm on the brake disk, you will not forget to take it off. You might be embarrassed, but you will remember the disk lock. The motion sensor is sensitive enough that all you have to do is swing a leg over the seat and drop your weight on it. If you didn't take the disk lock off, a 140 decibel alarm will go off. Just moving the handlebars without getting on the bike will set the motion alarm off. Using the key to take the disk lock off, you have 5 seconds to insert the key and turn it to unlock before the alarm goes off. I have been using disk locks for years. Only put the disk lock on if I am leaving the bike in a large parking lot or leaving it parked for several hours where I can't see it. Always use the disk lock when it is parked at a motel over-night.
