I recently asked for comparisons between the Kenda Kanine and Kuhmo tires. The reason I ask that specific comparison is I have a situation with a Vredestein tire. I went with Vredestein all the way around. The fronts have been great (175/55). The rear (205/65) are rubbing when going over a fairly big bump. I do have the mudflap which is mostly where it rubs. But there is some rubber on the actual fender. On occasion there is a slight burnt rubber smell also. I'm running 18psi.
The auto leveling system is working fine. Whenever I check the air pressure after a ride it is within 5lbs of what the chart says for the manual system. One up or two up.
When I look at my friends bike with stock tires it is very noticeable the gap between the fender/mudflap. He has substantially more clearance.
I'm looking to put a 205/60 Vredestein on but I'm not confident that will give me the clearance. The stock size would hence the question Kanine vs Kuhmo.
Thoughts????
Thoughts????
