Did You Ever Try To Push Start
che57vy
Anyone ever try to push start a Spyder? Believe me they do not like it, I had more fault codes than you could shake a stick at. And it still did not start it hit a few times and that was it.:gaah::gaah::gaah:
I've tried bump starting (roll downhill and dump the clutch). Spyder doesn't like that either but it did start. Used 2nd gear, 1st gear just drug the rear wheel. Had to do kind of like my dirt bikes, Dump the clutch and sit down hard over the rear wheel from a standing position at the same time or not enough traction to spin the motor.
(Just my non-mechanically-inclined brain here... :D)
Could it be lighting up like a Christmas Tree because you were trying to start it in a gear where it wasn't spinning fast enough? :dontknow:
If 2nd gear wasn't great; would 3rd maybe be better? With a much faster push or steeper hill of course!
I thought parking brake needed to be on in order to start
Hello Newbie & :welcome: .... This thread is over 12 years old .... and only applies to Manual transmission Spyder.;... So if you have an SE trans. it won't work .....Mike :thumbup:
I know this a really old thread. However I would think that the parking brake you speak of just does not allow the starter motor to be activated.
It is an old thread, and I believe it was originally referring to an SM5 bike too; and IIRC, the Spyders that weren't RT's or ST's back in 2011 all had foot operated ratchet style park brakes on the LHS!
But in the interests of clarity, then as Snoking mentions, I reckon that, at least on the SE's, it's not the PARK brake or the E-brake that's operated by the switch on the dash that has the Starter Motor Lock-out circuit attached to it, it's the FOOT brake! It doesn't really matter if you've got the Park/E-brake on or not, but you do hafta have your FOOT on the Brake Pedal or the starter won't kick in! :thumbup:
Just Sayin' :ohyea:
I know that I have responded to old threads in the past (it is very easy to do the first time), but I’m wondering if 13 years since the previous post is worthy of some kind of record :2thumbs: Perhaps a reward could be a wall mounted plaque of all tyre threads…….but it may be necessary to “build a bigger wall”:roflblack:
Pete
Pete
I dunno Pete, I reckon this one's just a pretty good 'ancient history' effort; after all, it's only a 'started in 2011' thread - the Forum goes back a couple of years before that, and we (the Mods anyway ;) ) have seen some real 'thread archeology' on the boards before; only thinking about that a bit more, you might not have seen too much of that, as it usually tends to be those dodgy type 'new members' who slip thru the pre-flights and then don't last very long who dig out the really old threads out by adding totally irrelevant or completely off topic posts?! :banghead:
But seriously, bringing up old threads by adding to the knowledge there-in IS NOT something we should be bagging too much - it helps us all, especially those searching for answers to specific questions, if all the knowledge is in one place/thread! :lecturef_smilie: It's really only when the 'question' added is directed to a member who hasn't been on the boards for many years; &/or it's not really on that thread's particular topic that it can become a problem!! :shocked:
Imagine how much easier the place would be to navigate AND for newbies to find the answers to the most commonly asked questions if the members who'd started all of those 'effectively duplicated' new threads, like all the oil or tire threads asking the same old questions, had simply done some searching & reading FIRST?!? :dontknow: After all, the Forum has been here for a fairly long time now, and there's not too much that hasn't been at least touched upon, if not asked and answered already... And there hasn't been soo many &/or sooo much of a change in the platforms & engines etc that the information/knowledge already shared isn't still valid &/or the differences readily identifiable! :rolleyes: And one of the benefits of a Forum like this over some other forms of social media is that none of this shared knowledge &/or experience is ever truly lost, it's a big data-base of collected knowledge & experience and it's all here, just waiting to be tapped and shared, IF people would only look FIRST! :lecturef_smilie:
Sure, it might be easier for someone to just start a new thread, if they're happy enough to let others do all the work and others are happy enough to keep on answering, but I reckon most who do that would be astonished at what they might learn just by searching and reading thru the older threads FIRST!! And only THEN, if they truly can't find an answer to their question, should they start a new thread/ask their question; which btw, they'll often very likely be able to ask better/more clearly because of some of that newfound knowledge they just read... ;) Yep, it'll take a bit longer, but they'll learn more and they won't make it harder for everyone else looking for the same/similar info later! And they won't annoy the crap outta those who've already answered that same question a number of times either! :ohyea:
Just Sayin' :thumbup:
But it still does pay to CHECK THE DATES on at least the first post in a thread AND the last few posts in a thread before submitting your own post/asking a further question - and it'd be even better to read thru the whole thread first too! :2thumbs:
I agree completely, Peter. I was not bagging the responder for replying to an old thread as, like you, I believe there is often additional relevant info to be gained from doing that. :2thumbs:
Pete
