3 Wheel Addict
Just picked mine up from the dealer that replaced the evap canister and I was told not to overfill the gas tank. Temps are hovering around 80 today on the ride home and upon pulling it into the garage and shutting it off I noticed an extreme amount of gas vapors pouring out from that vent line under the bike. If you hold your hand close to that vapor stream it is hot enough to burn you, grabbed the thermal gun and I'm getting around 167 degrees at that hose end, and that's venting from the tank!! The gas tank is between 1/4 and a half so it NOT overfilled. :banghead::banghead::banghead:
