Dan_Ashley
I just installed the Diamond-R arm rests. The installation was very easy. The arm rests look very nice. They are well constructed, and of high quality. The work well for my wife--she gives them an "A"!
I got the ones that are black, and they look really nice. They appear to be OEM equipment. Very nicely done!
For the installation, I just followed the instructions that came with the arm rests. The only addition I would make to the instructions is to loosen the set screwes on the bracket before you install the bracket. They were a little tight and I had to grunt to loosen them. This is REALLY minor though. Also, you need a 3.5 mm hex wernch for the set screws...not a problem, just so you know.
"Good job!"to Diamond-R!
