Desser Key Ignition error as Start Up
NorthEastJ
OK, so I am out today on my new 2014 ST SE trying to chip away at those break-in miles and on several occasion received a "Desser" error when attempting to start the Spyder. Also displays amber key symbol. Did it three times. Tried changing keys and it acted up once, but this time no error, just would not turn over.
Could this be related to the ignition re-call that I have read about. If so, can someone please post the link to the list of Serial numbers included in the recall.
On other unrelated issue I noticed today. When steering right to left at low speeds, I hear click noise at the exact point when the wheels reach the straight pointing position. So when I am in a parking lot making big S turns, when I reach middle of a hard right turn to back to a hard left turn, at the mid point of the transition when the wheels are pointing forward, I hear a little click. A quick visual of both sides of the suspension seem good.
I really don't want to bring the trike in before the 600 mile check-up because I'm having too much fun, but safety first.
My 2014 RT did the same thing this morning. The dealers here are all closed on Monday, so Tuesday will be my first time to have it checked. I hope it can be worked out, I have a 3 day weekend trip to Myrtle Beach this coming weekend.
Wow..!!
the long winter has kept this on ice...there were a bad batch of ignition switches check with your dealer they should change it out. :thumbup:
If key was damaged or the transponder chip is too far away will show
attachment.php
How dealer set you right, better to find out now & not @ spyderfest:banghead:
Check my post on the Dess Error on my 2014 RT. I had the same problem this morning. I tried the fix, and all is well. Dealers here open again on Tuesday, so I will still have it looked at, but now I know what needs to be done. I also checked my vin number for recalls, and there were none.
