Delay'd shift into 2nd gear under full throttle
Wildrice
I have a 2015 F3's SE6. I get this delay'd shift into 2nd gear under full throttle--approx 1 second. Other gears shift instantly. Does anyone else experience this issue & any solution to fix the problem??
Darrell
Darrell
Darrell, If you had the ECU re-mapped ( I think you did ) I would ask Steve about this issue …… Mike :ohyea:
Mike--it's been in Winter parked mode for 4-5 months. Maybe it needs to be loosened up. It's also a touch jumpy off the line--turning around in the driveway-etc--like it has a stall speed converter. But it sure won't hurt to ask Steve, I just need to put some miles on it 1st.
Darrell
Interesting....🤔
Guess you will have to give it some time and see if it clears up. Make sure you are making positive shift not ginger touch...:roflblack: it may be a hesitation as it passes "N" on its way to "2nd". The other gears just go straight on to the next....:dontknow:
No--under full throttle I have a firm grip on the handle bar & a firm thumb press on shift lever, we both agree--more time & warmer weather. It was 28 degrees this morning currently 42 degrees. I grew up on a small dairy farm next to Green Bay, WI thus I've had my fill of cold weather riding. Now I require over 50 degrees plus sunshine :-)
I know with my RT, if I am on the gas hard like trying to get out into traffic on the highway, it will do just what you are saying.
The problem in my opinion is that with the first gear you reach a number of engine revolutions too high and too fast and the gear change device loses some time x synchronize well the second gear to be inserted.
No--it could be that occasion--but I just talking about testing maximum acceleration between 1 3-4 gears thus I keep the throttle pinned wide open even during shifting.
I thought that power shifting issue was solved in the 1960's. The gears have a mechanical syncro thus if the gear is spinning at "X RPM" so is the gear change Syncro.
When I think back I believe I noticed this problem prior to any ECU upgrades--I have a very good memory--it's just very short:b2b: & not always accurate :-(
Darrell
Mine is weird...I will get what you are talking about but it has to be at one certain throttle position & load. But at WOT, it shifts hard and fast with no hesitation or "hiccup".... I think mine is a "transition point" in the mapping and its "severity" changes with running temps and outside air temp....
One would think the gear shift lever should be the controlling factor--maybe BRP isn't one of the ones who think that:shemademe_smilie:
Darrell
Might be closer to 1/2 second--but it's definitely noticeable . :-(
Well, there is "programming" involved for communication between the ECM & TCM, to cut timing and/or close throttle momentarily to allow unloading of the gears/synchros for both up and downshifts. This reduces wear and tear and supposedly makes for a smoother shift.... I am wondering if the actual electronic shift actuator solenoid is just a bit slow for the task....
I'm still exhausted from removing the cat delete & muffler & reinstalling it again--now I need to find a solenoid & time its transfer :-( Woe is me :-( Won't that be the same solenoid that controls 2nd to 3rd, 3rd to 4th, etc?
My 2017 F3 also rarely has. Can also happen from the second to the third. I mean it's because of a certain RPM engine.
