decisions ,questions & more decisions!?!
  • Thread starter Thread starter REDRICH05
  • Start date Start date
R
REDRICH05
Guest
:shocked: :banghead: :dontknow: please advise... #1 do the no magic 4" risers come back horizontally or just 4" vertically ??? #2 is no magic good quality,also the other products listed on the spyder lovers site? #3 is there a noticable difference in the 3 windshields brp manufactures. i'm talking comfort !!! #4 is there a fourth color brp's coming out with? of course that might lenghten my deciding on which to choose!!! i'm leaning towards yellow. it's the most visable color to the human eye!!! i do like the red also, but will it fade with sun & weather exposure??? #5 has anyone installed a back rest? how did it work out.. i checked out corbin, but why change a perfectly good seat when i just need a back rest? well i hope to receive your responses soon! sincerly ,REDRICH05 longisland,ny
1. I have the Kewl Metal bar setup. However, everything I've purchased from the Magic Man has been first class. I see no reason, based on his product's design, why the adapter bars couldn't be slanted back to provide more pull-back.
2. See above... good stuff.
3. You probably want an aftermarket shield for air control. I use a CalSci... also good stuff.
4. Don't know on the colors. I have both silver and yellow panels... change 'em out at will. I am partial to the yellow.
5. I have a Corbin with backrest. No pure backrests on the market YET. You could build your own based on a Utopia ... if you can weld a little, cut a little... and be willing to punch a hole through your stock seat. I did that on an ST1300.
Good luck!
Although not endless, the NMN Riser kit does allow for quite a bit of pull back if desired.
I have mine pulled back quite a bit as I like the closer riding postion. On the other hande some people push them forward quite a bit too?
The main thing is that even within the limits of this design there is still the ability to make that choice, something the stock set-up does not allow for. :thumbup:
MM
