spy_der_man
As of today the dealership is still working on it. It appears to be something electrical. Tech told me it's not wanting to spark correctly. Could be plugs, timing, etc....
Hi spy_der_man,
Re: It appears to be something electrical. Tech told me it's not wanting to spark correctly. Could be plugs, timing, etc....
I have spent a fair amount of time on a number of forums. Every now & then there is that one car, m/c, etc that just will not get going no matter what people suggest.
I really do wish you the best on this; you deserve it.
Jerry Baumchen
PS) And I hope that this might just solve it for you.
Can you tell us what was the final verdict & fix,..........
I dunno spy_der_man I guess you could look at it that way, if you believe in curses; but I woulda thought you would be thankful that your 'new' (even if 2nd hand) Spyder thinks enough of you to make sure you get all the iffy bits fixed early in your life of enjoyment on the Spyder!! It obviously didn't think enough of its previous owner to force him (or her?) to fix these things & was prepared to suffer a breakdown out on the road just to inconvenience its rider - but it thinks enough of you to want them sorted so you can enjoy the miles & smiles to come, secure in the knowledge that all the important things like brakes, oil levels, & plugs etc are sorted because you've sorted them!!
This is stuff is just your Spyder looking after you! :thumbup: Faithful rydes - if they like you!!![]()
... on the underside of the brake fluid caps, the rubber has a vent cut, it should be rotated near the little bump on the top of the plastic part of the cap.
