CanAmChris
I had the exact thing happen to my 2011 RS-S at the beginning of the season. Went for a ride, stopped for about an hour, went to start it to come home, nothing. Dash lit up with VSS and other lights, as soon as I hit the starter switch, the dash would die. I put a battery charger on it for a little bit and the starter would click rapidly meaning there was not enough voltage. I put a set of booster cables on it and hooked to a buddys truck and it took almost 20 minutes of running the truck to get enough charge in the battery to start the spyder. Got it home, and it died in my driveway. After troubleshooting everything, I found that my battery was internally shorted and causing a huge draw on the system. Got a new battery, been fine for the last 2000 km.
Same here with the 2010 RS-S. Parked her one night and the next morning. Lights go on then...click, click, click. Battery swap did the trick for me.
