DC Cigarrette/USB Plug
AMPERAGE DRAW
Cool, but do I need any kind of special harness or I go straight to the battery?[/QUOTE
If you are ever going to use it as a cigarette lighter I would suggest a separate in line 15 amp fuse to the Battery......If it's just an I-Pod or MP-3 or something with low Draw you can piggy-back onto a Hot wire .....because they are all fused ......Probably the best way is add a small extra fuse box or strip and use that............this way if you do any other add-on's down the road you will already have a safe device to tap into...........Mike :thumbup:
The cig plug I bought at Radio Shack (now out of buisiness) came with the wires and an inline 15 amp fuse.
So try to buy one that comes that way to asve hassle. Also make sure it has a rubber cap to help keep water out of it.
Bob
Bob
Got it thanks.
