Dazed and Confused.
Mcubed45
I've been reading about the heat issues. And, I getting ready to start working on my 2013 ST-L. My question is, does removing the catalytic converter solve the heat issue. If I do the PitBull bypass, is there no need for JT's air filter.
I know, I know. . . Do both. But my wallet says only one at a time.
After the heat issue is solved, then I can give BajaRon a call.
The cat bypass is a major heat source so i would tackle that one first and then judge whether or not you need additional relief. :thumbup:
Cruzr Joe
Have to agree..!!
:agree: JT's air box opens up the air space and improves performance but the cat removal will get the big heat out. Then when possible do the rest. :thumbup:
RESTRICT
THE CAT RESTRICTS THE AMOUNT OF 'GASES' THAT CAN PASS THROUGH IT.....
IT MAKES NO SENSE TO ADD ANYTHING PRIOR TO THAT.... THE ENGINE WILL NOT BENEFIT FROM TOP-END IMPROVEMENTS, UNTIL THE BOTTOM END IS ALLOW TO FLOW BETTER.....
LOOK AT IT THIS WAY: IF YOU CAN'T POOP (EXHAUST), YOU'RE NOT GOING TO EAT MUCH (INTAKE)..... ARE YOU? :thumbup:
DAN P
EASLEY, SC
SPYD3R
Look at heat wrapping your exhaust. That will be very inexpensive and makes an appreciable amount of difference in engine compartment heat.
