day runners
i am thinking about geting a set, could you post a picture from from side? i am wondering how it will affect gloriders. thanks
I will post pixs, after the install of all lights:2thumbs:
Do any of you have the LED Mud Flap lights installed as well? I did not spend much time on it this evening, but was not able to locate the connector with the wheel on yet. It looked like it was going to be in the box under the fender tip light, but it wasn't there. :dontknow:
LED Mud Flap Lights will be installed on Sat as well, will post pixs :2thumbs:
am looking at the new day runners in white, curious other than the install challenges, any other info on this product ?? They work good/bad, more visibility/ not, any other issues, electrical or ?????????????????:chat:
They work great! High visibility as Magic Man explained to me, this is not a spectrum of light your eye is used to seeing in nature and you are drawn straight to it. Front of the Spyder lights up great, and the light also shines through the side of the wheels which is an added bonus. Everything they make is plug and play, and not known for causing any electrical problems. :2thumbs:
reason for the question, previously purchased the triple play, fender tipz and the centre mount lamp, after hooking all this up had nothing but problems. NOTE MM WAS QUICK TOO FIX , but apparently I have one of only a few Canadian made units that this has happened too, so am kinda gunshy. thanks.
I completely understand the gunshy part. Hopefully you will not have any problems if you get these, except for having even more attention drawn to your Spyder that is. :thumbup:
