Spyderflyer1
As anyone out there tried to cut the antenna to make it a little shorter? If so, how much did you cut off and how did it affect the radio reception? Were you able to reinstall the rubber antenna tip?
Thanks for everyone's opinion. The only reason I was thinking of cutting the OEM was because I am having one hell of a time getting it off. I guess I'll keep trying and head to Wally World.
on my wife 2012 rt a/c was putting in the rear speakers. had to take off the whole back of the bike to put in the speakers. so when we got to the right side tried to remove the antenna and my friend broke it off. the lock tight that is used at brp is real good stuff. had to take the brass box that holds the antenna off and take my touch and heat it up and burn of the lock tight to get the screws out. I would try very carefully and not put to much force on it. it will break. you will be taking off the right side of the truck to fix it. good luck
