CTS
GRIPMAN
What are the consequences of changing the oem coolant temperature sensor with an after market one?
Ecu may not take the change, they are set to BRPS setting . Ck with a teck. Yours should still be ok unless you boled out of temp setting.
That would depend on if the replacement one was the correct part or not. If you chose one of a different range or electrical configuration, that could have lots of knock on effects. If you use a proper replacement part, there should be no effect on the bike or its warranty. You do not have to use BRP parts. Lookups for other brands are pretty spotty though and hard to cross reference.
Agreed!
Try this..!!
a second temp guage and sending unit. If you doubt the exsisting one. If your looking for a cheaper one (brp oem) you can get them online. Question still is why..?? :dontknow:
Why?
Aesthetics, and to match the Stack fuel gauge recently installed
