Cruise Control question...
You need to tell that guy that if he can't make up a plausible lie then the best thing is to say "I'm not sure, let me find out". I really hate when people just make up a lie when they don't know the answer to a question.
JT
:agree: :gaah: He's got to be able to think quicker on his feet than THAT! :shocked:
I think the issue also is RPM related. I use my cruise control a LOT here in AK and have never had any problems with it running at less than 45 mph. You just have to be in the correct operating gear and range. I recommend shifting up at 5000, and keeping the rpms in the 4500-5500 in any gear. For me, 5th is usually used for 65 mph and up highways.
We have discussed dealers by PM--so I will leave it at that. :D
Thread: Cruise Control question...
I have an RT SE5, 2010. I have found that at 45 mph the cruise control doesn't work. At 46 or higher it works fine. I live with it.
Low Speed Cruise Control Test
To satisfy my own curiosity, I took a ride to check the operation of the cruise control at low speeds. Normally, I just use it on the highway at 55+.
I rode the Eklutna Lake Road to Chugach State Park. This is a 10 mile long road that is uphill all the way to the Lake/State Park. It is posted at 35 mph and goes down to 30 when the road narrows and has some steep ravines on one side.
I was in second gear all the way, rpms at about 4200, and cruise control set at 32 mph. The cruise control worked perfectly all the way. As the road experienced a few uphills and downhills, the speed would vary + or - 2 mph or so--other than that it held, except for the couple times I touched the brake.
It appears, that rpm has a lot to do with when or not the cruise control will function.
Hope this information helps. :thumbup:
