View attachment 94811 The black piece in my hand is the piece to mod. The white panel above it is the actual switch. All the electronics are under the silicon. There are three switches to run the cruise. The on off switch is left center. The set up/down speed are right center. The raised bumps around the outside of the panel are LEDs. If you remove the dummy switch from your non cruise unit, you will find all the lettering for the cruise already on the bike. It even lights up so you can read it at night.
Again, the only difference in a bike with cruise and without cruise is the black plastic piece shown in
My hand in the pic.
