Cruise Cancel Switch
Do you have a cancel button for the CC in your cage? If not what makes the spyders CC so different that you need one on it? I don't understand why anybody would think this a faulty design.:dontknow:
Why yes, yes I do...
To clarify a bit, my personal situation is that I have a bad right knee and the movement to just tap the brake sometimes causes my knee to get a painful "catch" in it. So, that's where this idea got started.
By canceling cc you don't lose the set speed in cc memory like you do when simply cut it off. And, yes, every car I have owned with factory cc has had a cancel switch of some kind. Just saying...
Ok, I understand your reasons, but the only vehicles I ever owned with CC have been Fords and they don't have a cancel button, unless it's the upper end ones which I've never owned.
I'd like to have it also. HD has the right idea, just roll the throttle forward and it's off. Hit resume when you want it again. Much better. Than having to tap the brake. JMHO.
yes I do have a cancel button on the cruise control on the car. I don't have to turn it off,I don't have to touch the brakes and I don't have to downshift. I just touch that button and it cancels. Not having it is so 20th century
I have had "cancel" buttons on all my cruise controls in my cars for at least the last 10 years....and there is also one on my Victory Vision (throttle roll off) which I have had for 5 years.....and the Vision is cheaper than the Spyder. I thought it was on all cc equiped bikes. The Spyder doesn't have this? Thanks for the info, that could have been embarrassing :yikes:
We have a Ford Fusion(not high end). In the left cluster of buttons on the steering wheel, there is a button labeled "CAN/RES". This is your cancel button.
Left side on my Ranger is on and off, on the right side is top to bottom is Res, Set, -Cst. Next time I use it it I will try hitting the Res and see if it cancels it. I may learn something new. I never saw the need for all these fancy gadgets til I got older, always manual trans and crank windows and key lock doors.
I wanted to verify this before posting and I was able to tonight on a nice long ryde.
Once cruise control is set you can click up or down and each time you will go up or down aprox. 1 mph
If you hold the button in the up position you will gradually accelerate until you let go.
If you hold the button in the down position, the byke will gradually and smoothly slow down. May not be a cancel, but if I have traffic coming up I can hold it down to match their speed. Sometimes, if they are moving too slow I have to apply the brake.
I rarely use my brakes on the highway when approaching slower moving cars. A lot of factors come to play; how big a difference in speed, how far away is the traffic behind me, etc.
Anyway, something to play around with....
Well I tried it on the way home from work and so I guess I'm one of the lucky ones, the CC in my cage and the CC on my Spyder both work the same way.:D
All the cars I've owned with Cruise Control can be canceled by pushing a button and don't require hitting the brake or a clutch.
To restart the system, you need to reengage the speed setting by hitting the resume button.
On the Spyder, the same function is performed using the on/off switch instead of tapping the brake.
In my personal opinion, that seems very adequate. Living in the North East, I get very little opportunity to use the CC on any vehicle.
Nevertheless, the OP wants what he wants, and is entitled to his opinion. If enough people back him, then BRP may make the change.
I got a bag of crap from the forum when I recommended to have the average MPG and Distance To Empty shown on the LCD Display. I got comments about doing math in my head, and no one has needed it until now.
I would not, however, consider the cruise control to have a design flaw.
These are complicated and expensive machines. There will always be possible refinements.
Now that damn windshield arm................ THAT'S a design flaw.
My reason for wanting this is, when cruising down the highway and you see traffic slowing ahead or you want to just slow down for reduced speed zone, tapping a cancel switch makes sense rather than tapping the brakes.
[/QUOTE]
I find it easy, if paying attention to what's up ahead, to use the down tap on the switch to go to a slower speed. Also I find it easy to tap the break than I can just hit resume.
I agree "downshifting" will turn off the cruise but that will cause a more rapid deceleration. It's too bad that BRP just didn't allow for one more up shift (already in 6th gear) to cancel the cruise.
If you turn the throttle up, before downshifting, you won't experience "rapid deceleration" - in fact, you should do that. From my Owners Guide:
