cearley
I was trying to come up with an idea to eliminate the heat problem on the RT. This would require a big pair to say the least, not to mention some good wrench skills. This is what I came up with.
Add a second radiator of similar size mounted side ways into the reworked trunk, plumb it into the front radiator with a diverting valve so the flow can be controlled to either front or back. Remove the rear speakers and rework the housing to create duct work into the trunk. Mount a small axial fan on each side and wire them to the thermostatic temperature switch. With the fan mounted side ways there would still be room above it for some small trunk storage. In the summer the heat gets pushed out the back and for winter back to the front for those cold days when you need a hot foot.
Now all I need is to hit the Power Ball Lottery.:joke:
