I had the same question, so when I was talking to Harvey, at SpyderPops.com, he suggested that you shine a flashlight or some light from underneath toward the coolant reservoir. You will be able to see the fluid level and determine if it at the proper level (fluid line). If you try that before I do, let us know how it works.Is there a good way to check your coolant level?
Jerbear, my hubby is doing the work, I am just supervising and asking ????. thought it was best to ask Spyderlovers ???? While he was working. LOL
Just checked the level on my wifes RT over the weekend.My god,who designed this space to put it in!
Any way I tried a flashlight,no see coolant.Then i tried a long piece of a twist tie as a dip stick,no luck.
So I just started to pour some in and finally I could see it.Put just a little too much.
Pouring it in was no problem with a funnel and hose but to replace the cap was awful.
Ok thanks,new to this thing.Next time remove the panel (the one just like the oil check panel) then shine the light from there while looking at it from the front.
My bike is much easier to service!
Page 132 in the OM tells you how to check the level and gives some guidance on adding coolant but, removing and replacing the cap can be a BEAR. If you can get someone with mechanical experience to help, that would be a good thing. Not saying you do not have the experience. Just saying that the cap can be a bear.
Oil will deteriorate the rubber as time passes, and will also allow the rubber to remain slippery, which could more readily cause the loss of the panel. I recommend using water or spit as a lubricant.If you lubricate the rubber seal with a little oil you will be surprised how much easier it is to replace the cap!!:thumbup:
I stand corrected....will switch to spit I guess!
Ok my next ? Is do you only use BRP coolant or have you used any other antifreeze/water?
The silicone spray will preserve the rubber, but it also makes it remain slippery. That could contribute to loss of the panels, as easily as they are lost on a Spyder . I'll stick with water or spit.On my Goldwing, Harley TriGlide and now the Spyder, it is best to use silicone spray in each of the grommets before replacing the Tupperware snap-in pieces. This will preserve the rubber without degrading it in anyway.
