Considering a Leftover ST-S: Questions
newbert
My dealer has a leftover (ie - brand-new) 2016 ST-S that I'm considering making an offer on. Asking price (after instant rebate of $3500) is $17799. Although I've done research online, I'm new to Spyders so would appreciate any help with making this decision. My questions are:
1. The ST-S has the V-Twin engine which I know has been discontinued on 2017 model Spyders. The dealer says that maintenance would be "a little" more frequent on the V-Twin than on the newer engines. How does the V-Twin stack up against the newer engines with regard to reliability, etc?
2. What else should I be considering with regard to the V-Twin/ST-S vs. other models with newer engines?
3. Assuming comfort (my #1 consideration) is the same, would I be better off spending approx. $2k more on a 2017 F3?
4. Last, but not least (at least for now ;)), how much could I reasonably expect the price to be reduced by after negotiating?
Thanks!
Choices, choices
It's all in the test ryde. I must say I am a V-twin lover so won't fight the crowd on the advantages they feel the triple has but if you are planning long trips crusing and touring, you need a comfortable ryde. The only models left in BRP's line up is the RT and the F3. So this gives you an upright chair seating or a flat on your bottom seating. Try them out...I think BRP is having their test ryde program once again....:thumbup:
If Comfort is your number one consideration I would look at a leftover RT. I purchased a 16 RT for $2500 more than he is asking for the ST
I love my '13 STS SE5!!!! I was not comfortable on the F3, feet forward position was not good for me. I would say your comfort is the primary deciding factor!
Both engines are very reliable, the V-twin uses a bit of oil between changes, this is mainly because it is a higher revving engine than the 3 cylinder.
Mounting and dismounting are easier for me on the ST vs. the F3, I have 30" inseam with 2 hip replacements.
As for price I think the dealer is still a bit high. I bought a 2013 STS SE5 in May of 2015 and I was out the door for $14,000. So see if he will step up and give you a better deal!!!!
Yes, "out the door" includes taxes, destination fee...
Good luck!!!!:thumbup::thumbup::thumbup:
:shocked: Please understand that I'm not saying that the STs aren't great bikes: they are! :thumbup:
But the new bikes with the new engines and transmissions are that much better... nojoke
Thanks for that info!
Like you, I have a short inseam (29"). No hip replacements yet, but arthritis in at least one of them. So, YES, comfort is a priority, and the seating position on the ST seems just a tad bit narrower (and more comfortable for me) than an RT. (Haven't really been fit for an F-3 yet.)
When you say that the V-Twin "uses a bit of oil between changes", are saying that it tends to burn or leak oil and that you need to add oil to it in between oil changes? If so, that doesn't sound good to my inexperienced ears!
Thanks for relating your experience with pricing as well. I assume that everything is negotiable - just didn't know how negotiable.
As a disclaimer. The following text is my opinion only. Take it for what its worth. It's been my experience that anyone on this forum who doesn't think the F-3 is the best Spyder ever is routinely flamed by certain people on here.
If it were me I'd ride both an STS and an F-3 before I purchased. They are completely different seating styles and you might like one better than the other. For my own personal tastes.....you could not give me an F-3. The seating style (cruiser style) is a back killer for me. For you it might be perfect?
As far as reliability and power. I'd say the twin and triple are about the same. Having ridden both I don't notice a big difference in power from one to the other. The twin makes power at higher revs, the triple makes it at lower revs. Plenty of people here have put many 10's of thousands of miles on the twin with no issues.
BRP doesn't make the STS anymore and I'm sure dealers are dying to get them off the floor. Personally, I'd offer $2-3K less than the price you listed. Might not go for it but doesn't hurt to try.
Have a look at Cycle trader. You can find new STS and F-3 bikes on there (2015 and 2016) with really good deals if you don't mind traveling to get your bike..
I use about 1/2 qt of oil between changes. I don't think it burns all of it. I believe some of it is blown out the box. Definitely no leaks. I'm told this is normal. The twins have been around since 2008. They are pretty bullet proof.
I like the idea of the lower RPM's and less maintenance on the 1330. That was my main reason for going with a RT, and now a F3T. I do like the riding position on the ST, but I think the price that they are quoting you is way off. With the deals out there right now, I would be looking at a close to $14k or less out the door price.
Why would I prefer the 1330 bike, over the 998?
lower operating rpm
more torque (20%) at a lower rpm level
better fuel economy... longer fuel range
1220 watt alternator, versus a 650 watt magneto
dual radiators that reverse airflow when stopped... no hot air gets to the rider.
no valve adjustments
9300 miles (or one year) between oil changes (versus about half of that for the 998)
The hydraulic clutch engagement system on the SE models will prevent burning up clutch plates.
The old centrifugal system that is on the 998s won't...
(Only matters if you have the SE transmission.)
:welcome:
The 2K you save on the ST-S will disappear the second you drive it off the lot.
Discontinued both on engine and model style. In a year or so, no one is going to want an ST-S when considering a Spyder purchase.
Maintenance costs are about half. Oil changes 9,500 or once a year on F3. ST-S: 4,500 intervals with recommended valve checks ($800) every 14,000 miles.
And, I would recommend a test drive on both. The seating, ride, and ergos are different on each.
Let us know what you do. :yes:
another factor will be residual value. It will be/is much higher on the F3 since it is still in production and most people seem to prefer the 1330 and a 6th gear.
1330 or 998
I was coming from 2 wheels to 3. Rode both styles (motor) bikes and bought the F3-S. Love the torque and HP that the 1330 has. The laid back seat and forward pegs also made a big difference. Like others have said drive them both then pick which one you like.
how is your back?
If you have back problems, you would want to stick with an RT or RS so as to keep your feet under you. I will never be able to ryde the F3 any distance due to bone spurs on old fusions. You should be able to get a test ryde as BRP has brought the test ryde program back. Your dealer should have trained sales people plus a community advocate. Good luck.
I'm with you all the way on this. I was rear-ended last fall on my Ducati Monster 1200, and ended up with a fractured left wrist and torn LCL. I had LCL replacement surgery in January, and have realized I will no longer be comfortable riding two-wheelers, so I started looking at Spyders. I originally went into the dealer to look at a pre-owned F3, but after sitting on it, realized it was not going to work for me. They had a new "left-over" 2015 ST-S on the floor at a great price, and sitting on it was like night and day. Upright seating, no feet-forward stance, floor-boards instead of pegs -- a short test ride was all I needed! I've put about 1,000 miles on it in the last month and am looking forward to many, many miles more over the coming years. I would have appreciated the power of the 1330, but comfort is everything, especially for us old (71-yo) guys!
