major911
OK so I decided to connect the pigtail under the seat for my battery tender. Ive read all kinds of horror stories about the negative terminal something or other. I connected the positive side with no problems. started trying to loosen the negative terminal and it just turns and turns. Is there a nut on the back of that terminal? Looks to me like it's an extension of the negative terminal since the battery is supposed to be located on the left side there's no way this can be the actual terminal unless this is a long battery. can I connect this pigtail under the seat to the exposed terminals or must I remove the tupperware and put it directly to thew battery?
2011 RSS SE5
2011 RSS SE5
