Pineywoods36
Over the last month I have noticed the compressor seems to run more often than I ever notices before, what is the best way to test for leaks?
I am guessing there is a youtube video on air bag removal?I used a bunch of soapy water and was unable to find the leak until after I removed the airbag and bench tested it.
2dogs (nice username, that one, significant in any way??) Just about all air bags under vehicles will vary their pressure as the load & cornering forces change during operation, it's a function of the loading & height changes that occur as you ryde (& which must occur for proper suspension operation!) between the frame & the swing arm, which are the top & bottom mounting points for the air bag!! So you aren't gonna be able to get a 'constant pressure' air bag in there unless you disconnect & isolate it from one or both of those, & if it did remain at a constant pressure, it'd defeat the purpose of it being there!! This pressure increase during cornering is to your advantage tho, the increased pressure under cornering forces should help stop the rear squatting or lurching up & down as it would if it was just a constant pressure balloon fitted under there!! All this means is that it's true that the air bag works to maintain ride height & responds to changes in the ride height rather than trying to remain at a static pressure - in fact, it's pretty near impossible for an air bag used this way & installed this way NOT to vary it's pressure as you ride, & the 'piston' that the air bag sits on is designed & shaped just a little in order to limit any adverse effects on your ryding as you corner etc.
So what exactly is it that makes you think the air bag its pressure changes are what's making your cornering at hwy speeds interesting?? How are they interesting?? The bag & piston have been designed & tested not to make things interesting during cornering (despite the pressure changes which do & actually must occur) when they are functioning correctly; so if you are getting exciting events occurring as you ride & the air bags are functioning correctly as you've described their behaviour to us (apart from bleeding out overnight - that does suggest a slow leak somewhere) then there is probably something else wrong?!? Could be wheel alignment (& by that I mean not just toe in/out, but also camber & caster & all those other things that go into 'proper' wheel alignment on this sort of suspension!); could be failing DPS (Dynamic Power Steering)or a weak/dying battery causing the DPS to drop out every now & then; could be worn or loose components, A arm bushes, ball joints, tie rod ends, wheel bearings, etc; could even be dud shocks or springs.... Spyders are renowned for having 'interesting' steering, straight line tracking, & cornering straight out of the box &/or if they haven't had a good wheel alignment done (has yours?)
We really need a reasonable description of why/what it is that makes your cornering interesting before dissecting the ACS & compressor, it might be something else entirely!! :thumbup:
