Recluze
So here are some pictures of my version of Blue Knights cold air intake. Not elegant. It works. On a 200 mile run yesterday the intake temp (you can see the sensor in the second picture) stayed within a degree or two of ambient. This is probably a 15 degree cooler temp than it would otherwise get. Whether it helps enough to make it worth the minimum effort I do not know. I suspect that at slower speeds and higher temps it woudl have a worthwhile impact.
Note that I did not cut my air intake trumpets nor is the 'system' air tight. I hope this helps.
