Recluze
I came across threads on people making their own cold air intakes and thought it would be something I would like to do. It seems obvious that the colder the air going into the engine the better it would be. I have also had some concerns about how hot my new to me Spyder has been running. I have heard that the temp bars have been recalibrated, and while I believe that, I was so use to seeing my old Spyder run a bar lower that I thought I would find out what was real.
So I took a temp probe and put it in the radiator reservoir. I took another electronic temp gauge and put the sensor right on the end of the trumpet that leads to the air box. I did these tests with the right side bottom panel off and the wishbone center piece removed. Ambient was 75 degrees. Degrees in Farenheit
Bars Radiator Intake Fan
0 75 74 off
1 88 75 off
2 108 76 off
3 125 76 off
4 158 76 off
5 175 79 off
5 180-200 79 on
4 190 79 off
I took the temp probe out of the radiator and put the wishbone back in place for a road test. Right rear bottom panel still off. The test became a lot more dynamic at this point due to the speed traveled and the prevailing wind.
In Ambient
83 75 at 60 plus miles per hour
80 73 at stop light idle nose into wind
Conclusions I have drawn from these limited tests:
1) 4-5 bars is normal temp range for this engine.
2) Somewhere between 180-200 degrees water temp the fan will come on. At idle in 75 degree ambient it will cool the engine down to 4 bars.
3) There is not a lot of heat build up where the intake trumpets pick up the air- 7 or 8 degrees
4) The intake air gets cooler when at idle.
I can live with the conclusion 1 and 2 and will now stop trying to make the engine run cooler. Where it runs is about where I would think it is most efficient. I am surprised at how little heat build up at the air intake. I am mystified at why the air intake temp would get cooler at idle. I was pointing into the wind.
This was a short test run. I left my setup in place to do more extensive runs, preferably on a hotter day. At some point I am going to put the lower bottom plate back on.
0 75 74 off
1 88 75 off
2 108 76 off
3 125 76 off
4 158 76 off
5 175 79 off
5 180-200 79 on
4 190 79 off
In Ambient
