Code P1615 problem
drifterdan
I tried to start a new to me 2012 Spyder RT. It turns over, but, won't start. checked codes and got a P1615.(Loss of VTD Serial Data) Is there a way to reset the VTD? I believe it has to do with Vehicle Theft.
Thanks for any info you can give me.
When I look up Spyder Codes for a 2012 RT with Code P1615 reporting, it shows -
Module: ECM
TPS position deviation fault.
Throttle mechanical adjustment.
No initialization after throttle body/ECM replacement
Check throttle mechanical adjustment.
(B.U.D.S.)
So I reckon you might need BUDS to sort that one. :dontknow:
