Code P0107
Based upon what Roger posted about that code; you might just have a loose or damaged connection...
If somebody can tell you where that sensor is; you might be able to put things right by yourself! :thumbup:
Good Luck!
I don’t have an ST but the MAPS is on the intake manifold.
I rather imagine the connector needs to be shoved in.
I bet with the tupperware off it will be obvious unless the sensor is just plain defective.
Thanks
Ill try tonight and see what happens.....
