I'm trying to go off of what is on page 685 in the service manual to adjust the master cylinder rod. I believe I am getting code C004B after initially loosing the brake in an effort to lower the brake a bit. Now it seems I can't get rid of this code that pops up after riding a bit.
I've tried adjusting it over 10 times now. I'm not sure why it has to be so sensitive when deciding to throw this code.
If this code is being thrown for some other reason it would be greatly appreciated, however I haven't seen it listed anywhere online, nor on the My Spyder - SpyderCodes.
It was too loose for even the electronic parking brake on the 2013 ST to engage it, but I tightened it. Should it be tightened all the way until it actually starts to compress the rubber stopper?
Any assistance is appreciated.
Thank you!
Thank you!
