Clunk when going into reverse.
gabbman
Is the clunking sound when going into reverse normal ? I have a 2013 Se5 and it clunks when I put it in reverse or go from neutral to 1st. It doesn't do it when I'm moving and shifting through the other gears.
Mine produces a high pitched shine when backing out of the garage. No clunk though. It is obviously normal, but I can't figure out why it does that.
Here's the thing..!!
When going into first or revese your engaging an idle transmission after which all the gears are active and the shift are smooth. Most do it but the big twins are more noticeable...but it is normal...:thumbup:
probably related to the cold clutch shuddering. search my name & clutch. Should find TB I posted. I have the squeal also.
Benefits of Lurking
I'm preaching to the choir but, one of the biggest benefits of this web site is what a prospective buyer can learn from the experiences of Spyder owners. The issue of clunking into reverse or first from neutral was one of a host of things I learned of before I ever started dealing for my Spyder, so the day I drove off with it I knew it was perfectly normal. From many one learns a lot!
The clunk on the spyder is mild compared to the sound my friends harley makes.
Also a good salesman. Bob (my saleman) told me about the clunk from neutral to reverse or first before I did a test drive.
