clock and day reset everytime key off
GDA
Just lnstalled the canam heated grip .:clap:
The clock and day will reset every time key off.:yikes:
And the clock are not working after set to right time.
eg. set to 13:45 and it will keep showing 13:45 forever.
key off and on again become 00:00
Had remove the whole speedo when i install the heated grip.
Anyone had the same problem before?
Bummer...
:agree: your losing power to the consol. Back track and see that all the pins are good on the gang plug and nothing got pinched....
Bent contact for sure:banghead:, remove cluster and all contacts :yes:.
guys .thank you for the reply.
I took everything off again and check for fuse and conneters .
I found nothing .
Wanted to give up and live with it.
Before i put everything together ,i adjusted the high beam .
Magic happened and the clock start to walk again.
Very funny .
And here is a happy man again.
