:clap: Thanks for doing this video, Lamont! I have tried to explain this procedure several times, but it is far better in pictures than in words. One thing I would add, especially for owners of earlier RTs...it helps if you wet the pins a bit before pushing them into the grommets. I use spit (yuck!) but water will do fine if you are dainty. The wetness helps the pins slide through the grommet without pushing it through. The water (or spit) dries fairly quickly, and the dry pin is harder to come out than it went in, which helps prevent lost panels. I would not use any kind of lubricant on the pins or grommets. Some can deteriorate the grommets, and all make the panel come out too easily, increasing the chances of loss if your hook isn't properly latched. I also recommend gluing in the grommets with 3M Super Weaterstrip Adhesive or RTV silicone. Be sure and let the adhesive cure thorougly before riding. I also always pull softly at each corner after putting in the panel. If any corner is a bit looser than the others, you probably have failed to latch the hook, or a grommet has pushed through.
