bill pitman
Let me explain:
Our Spyder is a 2009 SM5 purchased in May of 2010.
Since early this year I've noticed a vibration/or shaking of the whole "console" and some vibration in the handlebars. Ride-on had been added , on a nice day ,I believe , in March. No, I didn't have the tires balanced beforehand. Who does! Well, Ride-On didn't fix my vibration problem.
So, June rolls around, I've got Elka's all the way around , a new Madstad windshield, you know, the ones that are really fun to get adjusted just right.... And my vibration issue. The trip to TN and NC is a couple of weeks away.
I decide,OK let's do it. I go to our local alignment/balance guru (Cole's Garage in Hainesville,NJ). We demount the tires(to rotate), I clean out the gooey Ride-On ,remount for side to side rotation, dynamic balance and leave with 2 balanced rim/tires. The long and short of it.... somewhat better ,but not good enough. What actually happened was, instead of a vibration at 53-55mph, it moved up a little(somewhere in the 60's)
Now, I do want to say, I did ,in fact, check out the suspension components in the front end and the mounting of the console prior to the above procedure.
Good trip to TN and NC ,including Kitty Hawk, Bay Bridge/Tunnel, put around 2000 miles on ,in the 8 days we were gone. AND always trying to find that sweet spot with no vibration.
So, I'm not a happy camper at this point in time. Gee, maybe the Madstad is causing the problem, change back to the original shield, same problem.
OK, let's revisit the suspension components- nothing bent, shocks/bushings fine, tie rods fine and tight,A-arm-bushings and sleeves seem OK.
I put the front of the Spyder up on jack stands. BALL JOINTS- I put a hand on each side of the left tire(at the top)and move side to side(with some force), there's play, a fair amount too. I do the other side , some play there too, slightly less than the left side. I check the bottom ball joints and don't feel any play.
9200 miles on this Spyder and at least 2 bad ball joints- how is this possible, quality checks lacking, inferior materials.
Could this have any bearing on my vibration issues? I did a search and found some other's have had problems also.
So I call my dealer, Jason says ,bring it in,leave it,and we'll look at it. I'm thinking, why can't I take it up there, we all look at it ,decide what's needed, parts get ordered and I drive home while parts are being gotten.
Maybe I'm wrong ,but that would seem a logical way to go about it.
Looking for technical help on this.
Thanks in advance.
CHECK YOUR BALL JOINTS.
Bill Pitman
Thanks in advance.
Bill Pitman
