Check Transmission
SemperFiSpyder
Owner of 2010 RT (A&C). I was on my way to the dealer this morning for my DPS recall repair. On the freeway, I was shifting between 4th and 5th gear at about 5000 RPM when the RPMs all of a sudden went up to about 6500 and shortly thereafter I received an orange screen on my display saying check transmission. I got off the freeway and limped to the dealer at about 5 to 10 mph with no power. Any idea what this problem is? Appreciate the assistance. :helpsmilie:
Check your oil level first. SEs are very sensitive to the proper oil level. Could also be a momentary electronic glitch. In that case stopping, then turning the key off and on several times should reset it...if it doesn't just go away on its own. Beyond that, BUDS should tell your dealer what is happening...bad GPS, bad shift solenoid, wiring or switch problem, etc.
Thanks
Scotty, thanks for the response. I got the diagnosis from the dealer yesterday. Seems like it is an issue with the clutch bearings which will require replacement parts from Can-Am.
Thanks for your help,
Ted
