Check out the new 2027 Can-Am Ryker!
Looks dfferent (lights etc) to Mondays reveal, AI generated, especially the voice?
YT seems to contain a lot of AI clickbait of Can Am's I've not seen before...
Well with the colors and shapes of the plastic's it really looks like some spiders I've seen in real life! All it needs is two long legs out front! 🙃
The orange one looks from the front a bit like a lawn tractor as found at Home Depot.
No, sorry, that was cruel.
They dropped the 600 twin for a 900 triple, but the triple only puts out 52 HP same as the old twin.
The other models still make 82HP.
Some changes to the steering, someone thought it is a steering damper.
LED lights OK, looks not so sure.
Lots of new luggage choices that everyone was asking for, wonder if they will fit the older models?
Dropping the 600 twin for a detuned 900 triple makes sense from a manufacturing perspective. The increase in the number of parts required is small compared to the manufacturing and support cost savings.
Some countries have Spyder’s classified as motorcycles and they have two tiered licensing schemes, with lower license classes determined by power output. I suspect this is partially the reasoning behind this decision.
I also suspect a detuned 900 triple has more torque that the 600 twin, which means it might have better real world performance than you would expect, hopefully at a lower fuel consumption on a cheaper octane requirement. Around town, which is where most Rykers get used, the lower power output might not be that meaningful.
If the bulk of the power reduction comes from a lower compression ratio, the turbo charging crowd might just love it, as they will likely be able to run much higher boost levels and subsequently gain much more horsepower.
I suppose we will just have to wait and see, such that when they enter the wild, whether some of my predictions pan out.
@mecsw500, I understand what you are saying (I worked in automotive manufacturing for over 30 years).
But most people don't read the spec's and I can see someone whining that their 900 is really slow.
Still, a 900 that is easier to turbo, Mummm. :D:D:D
I watched a YouTube video where there is a turbo kit specifically for the existing 900 cc Ryker.
I would suspect you could fit it in under a day with a lift to make it easier. It looked like quite a decent kit too.
After fitment, the Ryker was certainly quicker.
From what I remember, it wasn’t totally outrageous in price and there were no irreversible modifications to the bike. No drilling or cutting. There was a proper sump plate swap for oil returns.
