check fluid level sign
fdunham1
Yesterday I took the Spider out to go to the doctor. After seeing him waited about 1 hour I departed the Dr. office and went to the drug store to pick up my meds. When I returned to the bike there was a small amount of green coolant under the bike. I opened the front end and checked the level in the tank an it was down but not empty. As I live about 2 miles from the drug store I started up the engine and check fluid sign was on. Drove home watching the heat bars all the way made it home and let the bile cool off. Later that night put in BPR coolant to the correct level and restored the panel up top by fuses. Started up bike and the check coolant sign was still on. Now I called my dealer and asked him if I needed to bring it in to be hooked up to BUDS to clear this display, you guessed it he did not know. Does anyone know what is correct, I ran the mode and flash high beam test and got no error codes at this time.
Make sure they test the coolant reservoir and cap. Could be a crack:
