My 2008 Gs had the same, ended up being a Factory Recall DI'm getting a "Check DPS" warning on start up with fault codes P0551 and P0552 displayed on my 2011 Spyder RT. Any info would be appreciated, even if it's bad news. :yikes:
sorry to be the bearer of bad news.
I bet next your going to tell us there is no easter bunny , leprechauns, or Santa Claus? I still beleave dammit.OMG.... seriously this "key walk thing" really gets me. The "mystery machine" thing is nothing but a myth because people do not understand how the system works!
The reason this "seems" to work is how the system works.
While the key is on or engine running the bike has sensors all over it. ECM, VSS, DESS, DPS, and may others.
If some fault occurs with them they are reported to the ECM as "active faults".
Some cause an error on the dash, some do not. Serious errors cause LIMP HOME MODE.
Now here is the "KEY" yes pun intended.
When you turn off the key, then after a certain time, the system "logs" these active faults in the memory of the ECM and depending on the fault (yes some don't go away) they clear as active faults.
If you turn the key back on before this "timer" decides to log the faults, they will appear again right away as active faults.
THIS RIGHT HERE is the spawn of the key walk.... It's not about walking away with the key but waiting long enough for the system to change states!
FYI folks, the coil in the ignition switch cannot read the key more than a few inches.... So the MYTH about walking away with the key is TOTAL BS! Put the key in the glove box and the same will work.... The key walk is the BIGGEST BS myth I have heard here on SL since I got my Spyder. It's about understanding how the system works rather than some "mystical dance" with the key!
The point here is when you have to hit the MODE button to get past the start up screen you HAVE done the key walk! If you do not have to hit the MODE button then the Spyder was not off long enough for the system to change states. Thus active faults STAY active!
I am probably sorry to tell you belowme29 , but your probably going to see this error again and again. That DPS error is not enough to put you in LIMP HOME MODE but it will continue. The reason it is gone when you turn of the key and wait long enough, is the system clears the active faults and all looks good for a while UNTIL the DPS reports an error again over the can-buss.
Sorry but I am willing to bet you will continue to have this issue.
Bob
Bob
finless - your such a buzzkill. Just kidding.
Actually what you said makes sense, I guess I was using that terminology because I had seen it here - not that I believed in it. As you said the problem came back after 5 minutes on the Spyder this morning. I am hoping that this thing gets solved once I peel back the tupperware and wiggling some wires and clean come connections. The DPS was working fine until it seemed like I hit a bump and SOB was it hard to turn. Luckily I'm a big boy and can push the steering to where I want it to go. But I will not be going on any long trips with it - I don't know how bad this thing will get.
The first time that this error ocurred was at lunch, I left the bike for about 3 hours and the error was still on the Spyder when I drove it home. After getting home the error went away and came back this morning.
Oh well - there goes some of my money.
B.
The DPS is power hungry. Check all your power connections. Don't forget your grounds too. In particular battery connections and the jumper posts are tight.
BillyBovine - thanks for sharing this with me, I did not know that it was heavily dependent on power. I have seen a "blink" on my dash, where the dash looks like it shuts off quickly and then comes back on. So I would hope that this indicates a bad connection and that this is what is affecting the DPS. Fingers crossed.ray:
BTW - thank you for stepping me through this. This website is a great source of knowledge and people are passionate about what they believe in. Sometimes it nice to have someone give you the correct information and also correct you when you write BS. :thumbup:
Bruce.
I got the Check DPS Alert several times, starting with only flickerng, then full orange . When this happened, throttle acceration acted like the Governor wouldn't let me go over 50 MPH. My Dealer pulled the Codes, and made some adjustments to the Toe Out, and readjusted the Nanny Software on BUDs, and I was Good to go. The Alert has not come back on again, the last thousand miles, so problem appears solved.
We we are at the mercy of Good knowledgeable Dealers, with these HighTech Beasts! My Dealer is Virgal Naff Kawasaki in Lynchburg, Virginia. The Techs there are very knowledgeable of Spyders, as they have been a Can-Am Dealer for many years.
Jim
