BernieB627
I just got a new 2106 RS and found that the throttle control was too loose for my taste. If I took my hand off it, it sprang back to idle. SO, I removed the bolt at the end of the control from the handlebar and the inside of that plastic piece has 2 stepped rings. I found a thin rubber washer (I could have use inner tube rubber) that fit inside the handlebar but also around the larger inside ring. I then replaced the end piece and tightened it down just to where the throttle would hold in position, I used it this weekend on a 100 mile trip, and it worked great. A cheap throttle lock for pennies!!
