NancysToy
Motorbike Professor
..... the RPM is almost always above 1200 .....
????? The Spyder idle specification is 1350 +/- 50, so you should never see 1200 (or idle at 2000 either). If you do, there is a problem that needs to be corrected.
i always put premium fuel and the RPM is almost always above 1200, so in conclusion mine is not doing it because of the gas or the RPM's
:gaah:
the dealer is replacing the Clutch pack and i hope that takes care of the problem
:bowdown:
I final got my bike back. Woods fun center did a swell job no noise so far just did about 100 miles. It is running like new like it should
Sent from my iPhone using Tapatalk - now Free
They replaced the clutch pack and the chattering was still happening but much less prevalent. I stopped by again yesterday and the tech told me that he was 2mm off on the clutch install so he added a shim and is now waiting for o-rings/gaskets. Does this makes sense with an SE5? It should be ready Wednesday.
My dealer did this and it did not resolve the problem. I stopped at a different dealer yesterday and they told me that they had two out of 25 units come back with the same problem. One has been resolved by replacing the "centrifical" clutch, not the clutch pack, the other is waiting on parts. They offered to take mine in as soon as they can get another centrifical clutch. If this resolves the problem, I may have found a new place for service. :thumbup:
No cure yet.... FB's bike still shutters Studders and shakes at takeoff... It sounds like the pistons are swapping holes....nojoke ( I know that's not happening ....just a visual)Amazing .................. Same problem .................. Different cures :dontknow::dontknow:
Cruzr Joe
My ST has had several things replaced...not clutch......during a rear tire replacement...noticed the wheel bearings would not turn....shaved .00010 off stabilizer bar inside axle...that helped for awhile....while at spyderfest....it started again....BRP techs looked at it twice....finally answer....there is no fix...yet...this is a priority for the techs to find a fix.....we'll see what happens at Durango
My 13 RS-S makes a shuddering sound if I take off when the engine is still cold but after that its fine. Hope its not a sign of bad things to come.
