Bob Denman
Thanks!
I would certainly not do it with an RC battery charger. In fact, I would not recommend use of that charger at all, although in an emergency it would probably be OK if it puts out 1.25 amps or less.Sorry for the necropost. Don't know if this forum prefers a new thread or to post to an old post.
So I found this thread while looking RTS storage tips. Loving the idea of the cigarette adapter for battery tender. I hillbilly engineered a lighter adapter onto my new tender from an RC battery charger I had laying around.
The big question...is it OK to leave a tender on, using a lighter adapter plugged into the 12V outlet in the trunk, for six months of storage? I really don't want to set the house on fire and give my wife and kiddos something else to worry about while I'm away.
Thanks so much for any info.
John
Sorry for the misunderstanding. The important part of motorcycle charging is the correct saturation charge, followed by a float charge to maintain the battery without damage.I think I was misunderstood. I do have a proper motorcycle battery charger. I just cannibalized the lighter plug adapter from an RC charger. Adapter is a proper Radio Shack product. Just took it off the RC charger and put it on the MC charger.
Glad to hear six months on the charger shouldn't burn the house or bike down. Thanks. Other than missing family, being without the Spyder will be the toughest part of being gone.
It is OK to leave the battery on for long term use, if you use a charger/maintainer, made specifically for motorcycle use. Battery Tender is a brand that is well known and readily available. I prefer the lower output Battery Tender Jr. for long-term use. Chargers by Accumate and Optimate are my favorites. The Xtreme charger may be the best for long-term use, with its pulse charging feature, which fights sulfation.
One thing is guaranteed, if you don't charge the battery during long-term storage, it will suffer! You can remove it or leave it installed, and charge overnight every week or two, or you can attach a motorcycle charger/maintainer and just leave it on there.
Ditto on the plug from Radio Shack (5.95) Worked like a charm because of the push in connections.I just took a standard Battery Tender end with the ring terminals (I have lots of them!), cut the rings off and attached a cigarette lighter plug I got from Radio Shack. Easy as pie and works like a champ.
Plug was %.95 at the Shack. Push in connection was very easy and it works great on my RT.I wasn't blessed with a surplus of parts and I wanted to keep the "regular" connectors available in case I needed to hook this up to something else here in the dungeon... (How much does one of those Radio Shack plugs cost anyway??)
Someone mentioned using the 12 volt outlet to charge the RTS. Does anyone have a brand name recommendation for this. Battery tender does not make a 12 v attachment. I am looking for something I can leave attached to the RTS for several months over the winter to trickle charge.
click on link Home Depot for $20.00
http://www.homedepot.com/webapp/wcs...&cj=true&srccode=cii_5784816&locStoreNum=1110
Freebob...:doorag:
:hun::crackpipe:I don't need a battery in mine.
I installed a ZPM in the trunk and ran a warp plasma conduit through to the engine.
I'm trying to find a warp core to replace the engine with.
That setup should last for about 10,000 years.
I'm having trouble finding a spare warp core though....Oh well !!!!!
maybe the Russians have a spare nuclear reactor from one of their decommissioned nuclear subs lying around....
cheers
:roflblack::roflblack:hyea:
hyea:
