Can anyone tell me if these instructions apply exactly to a 2021 RTL or is there newer info on 2020+ models?
This thread started out back in 2015 as a 'How To:' DIY description for a
2013 ST, which would've meant the instructions were also fairly applicable to the 2010 - 2019 RT's..... That said, while there are clearly a few minor differences between the ST's & RT's of that vintage, and even more differences between them & the 2020+ RT's, when it comes to changing the rear tire, I believe that most of the frame is close enough for these instructions to still apply to your 2020+ Spyder. :thumbup: However, be aware that some time around 2017/18, the rim changed from being a 2-piece rim that could be separated, making it easier to strip/refit a tire on traditional tire changing equipment, to a 1-piece rim - meaning it's still not impossible to change a tire on it using the tire changing equipment your local tire shop is likely to have, but it'll definitely make it somewhat harder for anyone less than a skilled & competent operator with a little bit of a flair for thinking & operating outside of the 'traditional' box! No real difference or a biggie for anyone using manual strip/refit equipment or even basic tire irons tho!
So all that said, these instructions might not apply
EXACTLY to a 2021 RT-L, but in all significant &/or applicable respects,
they should be close enough to work for most operators. It's not really all that difficult a task,
IF you can get down there
but there are a few fiddly bits & it will probably take you a bit longer than you might expect when you're doing it for the first time. Pay attention to how the speed sensor is mounted & where any shims used on it might go, cos you
REALLY don't want to damage that sensor or the wire, kink or over-stress the wiring, or get the sensor's clearance/flying height above that notched wheel wrong on re-assembly; and you don't want to damage or bend the notched wheel either (it's the spinning part of the speed sensor); nor do you want to 'clock' the drive sprocket incorrectly when re-fitting it either! :thumbup:
Oh, and I find it a whole lot safer to actually
TAPE the belt tensioners on the ends of the swing arms into place - just run a 9-12" long piece of duct tape or similar a few inches or so along the top of the arm, down over the end of the arm & the tensioner/tensioner bolt, then along the underside of the arm for a few inches. That way, the tensioners can't fall out or the bolts be turned, & when you walk the belt off during wheel removal & back on again during the wheel refit, you should find it easier & you shouldn't need to re-tension the belt afterwards, altho you should check it anyway!
But if you get the wheel refit done correctly & the axle tightened up squarely & properly, it should all go back exactly where it was before it came off!
hyea:
Over to you! Good Luck. :cheers:
