Look here for wraps....http://www.centuryperformance.com/exhaust-header-heat-wraps-do-not-use.html....opcorn:
If you read the article I posted it tells you why you should NOT use a wrap but it is your bike:thumbup:search in this forum for exhaust wrapping 2 , under midlifecrises member -he has pictures ! I will post some of my own at the end of the week. :ani29: in shop ...:banghead:
Quote from frank3 on 8/07/2013... "FYI, removed both headers 2 years ago on my 2010 RT-S, had them ceramic coated. Coating didn't make much of a difference so this year I removed the headers again and wrapped them in 1" with a much better reduction in heat. Don't bother with the ceramic JMO. "
The article is a little over dramatic to say the least, not to mention the temp readings from the coated headers are purposely MISLEADING.... Jet Hot and the like historically use an IR temp gun to gauge surface temps which unless they are "calibrated" for a reflective surface are USELESS and will register much less than the actual temp.
We've worked with headers / exhaust systems ranging from 5hp mini bikes to 4500HP+ twin turbo shoot out cars for close to 15 years. There are "extremes" in any application that tend to be the EXCEPTION and not the rule. Most headers / exhaust systems that experience cracks or fatigue are the result of bad welds, insufficient material, and or a combination of both in a stressed or structural application. i.e. various exhaust components are being used in a structural manner and not properly speced.
There is some validity to the advantages to coating the pipes in that Ceramic Coating functions as both a thermal barrier and also dissipates heat from its surface. In that the Spyder is a relatively mild application i.e. normally aspirated, open air and seemingly constructed from SS, you have very little to worry about. Keep in mind if these pipes are in fact SS, that is the primary source of your thermal issues. SS is great for thermal shock and a strong substrate for exhaust components but because it is denser than mild steel it keeps much of it heat on its surface much like a heat sink and it takes longer to dissipate if not aided by any coatings.
You may be right about the stainless but
Examine these actual test numbers:
- Mild Steel (1010) uncoated header exposed to continuous 1200º F. in normal air will have a weight loss percentage of roughly 25% with only 10 hours use at this temperature.
- Stainless Steel (410) uncoated header will have roughly 8% weight loss in the same 10 hour period.
- A coated mild steel header will have NO weight loss at temperatures up to 1200º F. In fact it will actually gain a bit of weight! Between 1300º F and 1600º F the coating will begin to show signs of mud cracking or like the look of lacquer checking. However, limited diffusion takes place between the coating and the substrate, producing a very thin film of iron aluminide, which continues to inhibit oxidation
So there is more benefit to coating SS than running naked
Its beneficial to coat ANY substrate, each for different reasons. Beyond aesthetic concerns, SS benefits significantly from reducing radiated heat from its surface. In really thin SS / TI pipes you benefit from Thermal Control. Mild steel needs corrosion protection and a thermal protection, etc, etc.
As for the data above, I'm not buying it. we certainly see corrosion issues over the years as a result of both thermally induced factors and environmental factors. If these headers were losing 25% of their mass that quickly the headers would literally "float off the engine". By his definition most normally aspirated drag cars and road race cars would be going through "multiple" pairs of headers in a season. I've never heard, nor seen such "accelerated" corrosive conditions in my life. Case in point, look at a class 8 / over the road truck of a few years back with a mild steel exhaust. Under load / boost these trucks run FAR beyond these temps and do it for 100's of thousands of miles and 1000's of hours without replacing exhaust systems........
Going further with the bizarre analysis, he goes on to describe an "over temp / delamination" scenario in which the ceramic coating begins to break down and become sacrificial. He then describes the iron oxide / rust as inhibiting rust???? This makes absolutely no sense. As you can see from a the examples below below, his description is in NO WAY indicative of how ceramic coatings react and or fail...........
I'm a little confused at the outcome of this discussion? Are you saying it is beneficial to "ceramic" coat our stock header pipes whether they are SS, or mild steel...or not?
"This may not be totally true for a 100hp engine but if NASCAR experts say this I tend to think about it."
NASCAR is an advocate of change to E15 fuel. I guess they are correct it's a great fuel if you tear down and rebuild your engine every 500 miles. For the real world it SUCKS guess they are the same as other "Big" organizations give me the money and I will endorse anything.
J. D.
:lecturef_smilie:Anything and everything will rust over time, even stainless will oxidize over time -it the nature of the beast! with that being said, if you coat and wrap your pipes you must add this to your list of yearly checks and maintance. it will NOT last a lifetime and will be needing recoating or bandage changed at some time. if you do it right and take your time it will last a long time though- and keep your :spyder2: Kool! NO pro here, but I have hands on experience on the subject at hand.hyea:
Absolutely beneficial to do Ceramic Coat them and or wrap them.
Wow that was an expensive lesson.
I wonder how the "wraps" affect performance?
Or is it "effects", I always get them mixed up. :roflblack:
The correct spelling is "effects" I think?
The answer if you own a 2011 RTL, SE-5 is it appears to have had none. But one positive effect. It made the Rt run much quieter. It took the pinging noises generated by the exhaust gases and knocked them down immensely.
