Spyder_Cowgirl
GOS member (Girls On Spyders)
I have searched and found similar problem to below ... but no answers that seemed to fit. Recent 14K service and the CB was transmitting just fine prior to the service, crystal clear, no issues. Now, after the service ....
UPDATE: Spyder_Cowboy (aka hogcowboy, aka injuncowboy) just pointed out that the new air scoops were installed as well (for the 2013 heat problem -- BRP did a good will retrofit onto my 2012 RT Limited due to heat issues during the summer). This means that all that baffling under the Tupperware was removed for air flow -- again, not sure if related (but definitely worth mentioning).
Dealer is willing to look at this, but does not have any way to test (no CB to receive transmission). So, to expedite the fix .... what do you CB / electronics experts think of this problem? :chat: Note that the spark plugs were changed during the service (as required), but do not know if that is related. Also, I did notice when I picked the bike up ... the clock was at ZERO and I reset it when I got home. Seems odd that the clock would be set to zero -- what causes that?
Help .... :hun: ... I am stumped -- Ann
- Sounds fine transmit and receive when the engine is not running.
- Receive is fine, but transmit contains a small amount of static / noise even at idle and the amount of static / noise increases with the engine speed (to the point where the receiver cannot understand what I say -- all they hear is static / noise).
