cb radio wiring
jake6470
I have the J & M radio mounted on the handlebar, now I have to run the cabling. There's an unused rocker switch covered by what looks like a plastic tab. Does that just pop off? If so I can run the antenna and power cable through there.
Thanks in advance for any tips.
Jake
Hubby connected mine a little differently. He removed some of the Tupperware and then connected the J & M cable to a hot wire. That way the C B comes on when I start the bike. He removed the FM antenna and replaced with the C B antenna. I had no use for the FM antenna since I listen to the iPod. The hardest part of the install was manufacturing a bracket for the handlebar but sounds like you have that nailed. Good luck with your install.
