IdahoMtnSpyder
I've been reading threads till my eyes are bleary, but I don't find the answer. I read many threads about problems SL members had with their BRP CB causing a squeal when they pushed the PTT to transmit. This problem apparently reared its ugly head with the advent of the 2014 RT. Well, I've got the same problem with my 2014 RTS with a 2015 model of the BRP CB and driver headset harness that I bought from a fellow SL member. I used the entertainment harness and antenna and coax from my 2013. I never had a squeal problem with the 2013 RT.
The usual causes of such problems are, and my situation with regard to them are as follows.
A squeal can be result of a high SWR (standing wave ratio) so that's where I started checking. My system is showing an SWR over 3. It needs to be less than 2.
High SWR can be caused by a bad ground. Ohmmeter check shows I have good continuity to ground from the coax shield.
A shorted coax will cause the problem. Ohmmeter check shows I have no short in the coax.
A broken center conductor will cause a problem. There is good continuity from one end to the other of the coax so it's not broken.
A smashed or bent coax will cause a problem. I bought a new coax. It did not improve the situation.
A broken wire in the antenna will cause problems. An ohmmeter check of the antenna shows full conductivity from the bottom to the top.
An inadequate ground plane will cause a high SWR. I wheeled a 2' x 3' steel table next to the bike and connected the coax ground to it. Voila! The SWR dropped to about 1.5! Oh :cus:! The squeal still occurs. Obviously it must not be caused by a high SWR. There must be a common root cause for both the squeal and high SWR.
Induced signals in the headset harnesses can cause feedback. Disconnecting the driver headset harness from the entertainment harness did not solve the problem.
Acoustic feedback from the helmet speakers to the helmet mike will cause feedback. The squeal still occurs even when the headset is unplugged. I hear it in the handheld I'm using for testing so the squeal is being transmitted and not just limited to the bike helmet headset.
Have parts been updated that could be the answer? The radio has been updated, and the one I got is the latest version. The antenna, coax, and mounting block are the same part numbers as five years ago. The newer entertainment harness wiring configuration is the same as the old one I have.
My question is to everyone who had a squeal problem with your CB. Did you get the squeal squelched? If so, do you know what the technical fix was that solved the problem? I read several threads where the dealer changed out all the components but the squeal remained. So it must be caused by some interaction between the CB and some aspect of the bike that is not an integral part of the CB.
Has anyone successfully used a Non-Ground-Plane antenna? You have to use an NGP coax or it won't work. Not doing so may have been the reason a couple of users reported an NGP antenna didn't work for them.
I installed the CB myself and have done all the trouble shooting myself. My dealer has almost no experience with CBs and since I bought the CB in a private sale BRP won't lend a hand. The dealer did give me a copy of the installation instructions. They're almost identical to the one from five years ago. Plus, the dealers mostly just swapped out parts for most of the SL members who had this problem, and mostly that didn't help much. I'll send an inquiry to BRP and see if I can get an answer from them, but I'm hoping someone who got theirs fixed knows what the fix was.
