cb problems
tidlewine
Had the dealer install the cb option on my RT. Receives fine, but cannot talk on it.
When pushing the ptt button it squeals in the speakers in the helmet. The exterior stereo speakers are turned off.
The dealer does not know what to do to fix the problem. Anyone have any suggestions?
Tony
What he said
It sounds like you may be over driving the radio. On the other hand it's just possible that there is either no or a faulty ground connection somewhere in the antenna wiring. Frankly, I've not heard much good from people I've talked to about the CB, most of the comments dealt with trouble transmitting and being heard and understood by the other party. I also know that Sierra Electronics in Troy, Ohio makes or has made a replacement mounting block for the CB antenna. If you continue to have problems you may want to investigate that option.
Ride safe,
Tony
My Wife has a 2012 R Limited. Dealer installed new CB Radio last May. Does not transmit now. Spent a day with the tech working on it. I'm old school and know CBs well. Dealer and I tested (ohm) out all wires ect. Dealer has no idea. At this point I'm waiting on dealer to contact BRP. Did you get yours repaired?
My friend had a CB installed on his 2013 RT Limited and the transmission & receiving range was less the 200 feet. Brought it to a different dealer to check installation and found the wiring was screwed up, got it straightened out and now have a range of 1.2 miles much better. Not as good as my Wing but OK.
