CB problem.
wingnutgl18
CB works ok as long as I'm the only person using the CB. I can transmit and receive ok. When I hook in my passengers headset, I get a loud squeal along with the voice transmission. Even if I just push the transmit button without speaking, I get a loud squeal. Any ideas out there??? This applies to my 2014 Spyder RT Limited. As an after thought,,,,,,if you take the cord going to the passenger headset and just hold it in your hand, the squeal is not present. If you disconnect the riders headset and push the talk button, it work ok with the passenger headset. Checked with the dealer and the service dept had no idea what the problem could be. Any suggestions???????
No Expert
Mind you, I'm no expert ... but I seem to recall from trying to install a CB in a car years ago that the squeal can be caused by a grounding issue. Like maybe the secondary CB port isn't properly grounded. Have you tried plugging in, solo, to the rear just to see if it works by itself?
Best of Luck .... Ann
